Author Topic: TLC59711 LED Strip Driver  (Read 136 times)
Offline 24602Topic starter
« on: Yesterday at 06:42:26 am »
Hey All,
Working on driving 12-24V LED strips from a TLC59711, I have attached a schematic
Just need a double check of the work and confirm would the Gate voltage be ok at 5V?
Need a double check if my Transistor and mosfet combination is correct.
Will be driving approximately 1A of LEDs per channel
Thanks!
Offline ahsrabrifat
  • Country: pk
Re: TLC59711 LED Strip Driver
« Reply #1 on: Today at 06:06:24 pm »
You can add a small gate resistor (e.g., 10Ω) in series with the MOSFET gate. It will limit the inrush current.
Online Ian.M
« Reply #2 on: Today at 07:08:38 pm »
What inrush current?  The gate charges to turn on the MOSFET via a fricking 10K resistor!
The PWM period is about 50us, (nom. 10MHz internal greyscale clock divided by 512, see datasheet: Figure 22. ES-PWM Operation) and I suspect the above gate drive circuit will be *far* too slow.
Edit: confirmed by simulation.  Wont work!  :horse:
« Last Edit: Today at 07:48:47 pm by Ian.M »
