I know that this post is a bit old but for future reference, here's some curve tracing with 2 different AWGs.
Apart from the AWG and the Oscilloscope, all that's needed is a couple resistors and some care on the values chosen, so the AWG will not be overload.
So here it goes, something like this: "Forgive me the crudity of the schematic, I didn't had the time to put it on scale or to paint it"
Option 1) Results with the more recent test gear, AWG: Siglent SDG-1032X (Max.Iout: 200mA) and Scope: ISO-Tech IDS-2074E
EDIT2:
Something posted on an GW-instek GDS2000E scopes that adds to the subject.To draw a PNP curve in the same way as a PNP, invert ch.1 and ch.2 on scope
Option 2) Results with some old/cheap gear, AWG KKmoon MHS-5225A and Scope: Tektronix 2445
For NPN: BC547B
For PNP: BD140
Setting the signals needed on the SDG-1032X is fairly easy. He has built in the ramp and 8 step signals.
But the MHS-5225A only has the ramp, so the 8step signal had to be built (rampup_8steps.csv attached). For the PNP transistor is just a matter of inverting the signals.
MHS-5225A settings for NPN
MHS-5225A settings for PNP (ch.2 on the scope is inverted)
EDIT: In all cases, don't forget to set the proper signal offset so they start at 0Volt
Steps vs value to be set for the 8 steps ramp-up to set a csv file for the KKmoon Generator
built on Excel, setting the same over the specified rows
----- Rows ------
first -------- last --------- value (on column A)
0001 ------ 0256 -------- 0
0257 ------ 0512 -------- 0.142857
0513 ------ 0768 -------- 0.285714
0769 ------ 1024 -------- 0.428571
1025 ------ 1280 -------- 0.571429
1281 ------ 1536 ------- 0.714286
1537 ------ 1792 -------- 0.857143
1793 ------ 2048 -------- 1
[EDIT2] to (re)place the pictures along the post
