hello, im tring to understand the circuit so i will try to explain what i understand. if i get somthing wrong and you can correct me i appreciate that.
the circuit is for RTD 3 wire configuration from TI (
http://www.ti.com/lit/an/snoa481b/snoa481b.pdf)
as much as i understand:
U1D / U1B / U1C are for voltage reference which is concerning this topic.
i don't know about op amps and their types, drift, noise, common noise rejection, ...etc.
its like black box for me so I'm trying to understand with idea of (these are ideal amplifiers).
1- we have 1.25V from
LH4140ACH-1.25.
2- I'm going to ignore that this 1.25V is connected to
R19 for now.
3-
U1D positive input has 1.25V.
4- U1D will try to follow the input so its output will be 2.5V. because
R21 =
R225- we have (the output going to the RTD (
R6) with the resistors shown:
(1636 / (1636 + 634)) * 2.5V = 1.802V is going to positive of
U1B6-
U1B is just buffer so its output is 1.802V.
7- i assume that (
R15, R16, C1, C2) is just filter and what is going to
U1C is just pure DC 1.802V
8-
U1C is just buffer
9- at top of
R19 we have output of the
U1C which is 1.802, and at bottom of
R20 we have 1.25V (difference = 0.55V)
10- across
R19, R20 is 0.55V so that will be /2.
11- input of
U1D = (1.25 + (0.55/2)) = 1.525V
12- go to
step 4. except we have bigger voltage
this means it will keep increasing the voltage?
