Electronics => Beginners => Topic started by: muthukural001 on September 09, 2020, 09:44:45 am
Title: Can I get Transformerless ac-dc for 30-40W
Post by: muthukural001 on September 09, 2020, 09:44:45 am
Hello All,
I am looking for transformerless ac-dc converter module which supports 30W-40W...I have looked at monolithic's AC-DC module solution and looks like they do not have transformerless for 30W-40W...If anyone have come across this, please share...
Thanks and Regards,
Muthu
Title: Re: Can I get Transformerless ac-dc for 30-40W
Post by: capt bullshot on September 09, 2020, 10:13:29 am
What about these:
https://www.mouser.de/Search/Refine?N=18337911 (https://www.mouser.de/Search/Refine?N=18337911)
SCNR, You'd have to give more specific specifications for better answers ;)
Anyway, a "common" AC/DC for e.g. 230V AC to 12V DC at 40W wouldn't be transformerless at all, since it's technically no good to not use a transformer in this particular case.
Post by: muthukural001 on September 09, 2020, 01:37:47 pm
Our req is 5V 6A (30W) output from a AC-DC converter module which should be transformerless...If 30W without transformer is not technically possible, we are even okay with 15W transformerless ac-dc...Please anyone suggest
Thanks and Regards,
Muthu
Post by: capt bullshot on September 09, 2020, 01:58:52 pm
Thanks and Regards,
Muthu
If your input is e.g. 8V AC, for sure you can build a transformerless suppy module outputting 5V DC / 6A using a linear regulator.
What's the reason for "transformerless" ?
Under "normal" circumstances, there's no reasonable way to build such a supply (no matter if 15W or 30W) operating with mains voltage input. A typical "transformerless" DC supply running from mains can be either built using a high voltage buck converter, or a capacitive dropper circuit. The latter one typically delivers some 10mA, the usual single inductor buck converters operating from mains are in the 1W output power ballpark.
Post by: bdunham7 on September 09, 2020, 02:05:59 pm
Is the AC the 230VAC mains?  Or is it something else?
And by 'transformerless', do you mean you don't want a typical step-down transformer followed by a bridge and linear regulator?  Or that the device, for some odd reason, cannot contain any inductors at all?  That would be a pretty odd requirement and makes a simple task almost impossible.
Post by: muthukural001 on September 09, 2020, 02:40:44 pm
Hi guys,
What about our mobile charger ?. It should have transformer but not a bulky one, that's why they are light weight and compact. I think that I should use kind of that transformer to acheive 15W (5V 3A)...  For 30W support, I am not sure the same light weight transformer will do the job or it will require a bulky one.
Post by: tunk on September 09, 2020, 03:16:09 pm
That phone charger is a switched-mode power supply (SMPS)
as is almost all of todays power supplies:
https://en.wikipedia.org/wiki/Switched-mode_power_supply
Edit: and it should not be a problem to find one with 5V and 30W.
Post by: bdunham7 on September 09, 2020, 03:25:39 pm
OK, so what you apparently need is readily available commercially, although it is not technically "transformerless":
https://www.meanwell.com/Upload/PDF/IRM-30/IRM-30-SPEC.PDF (https://www.meanwell.com/Upload/PDF/IRM-30/IRM-30-SPEC.PDF)
Post by: langwadt on September 09, 2020, 03:57:26 pm
why transformerless?
Post by: dmendesf on September 12, 2020, 03:07:32 am
https://www.st.com/content/st_com/en/products/power-management/ac-dc-converters/high-voltage-converters/viper/viper53e-e.html (https://www.st.com/content/st_com/en/products/power-management/ac-dc-converters/high-voltage-converters/viper/viper53e-e.html)
Post by: TheHolyHorse on September 15, 2020, 06:26:20 am
 I think his requirement is compact size rather than transformer less.
