Thanks,
I am using UCC28070A as a Boost PFC controller ...it also gives the fet gate drive signals.........so, before i let the Boost loose on the load, i wish to see the gate drive waveforms, so we can check the fets arent being permanently held on whatever..........so i have a series gate resistor we can unsolder for that......trouble is, when that is done...the Boost would go into shutdown, and not give the gate signals that we want to inspect......so we want to put 3v direct into VAO pin so the boost controller still sends gate drive signals even though the fet gates arent actually attached....
