I'm trying to debug an inverter fault on a heat pump and to make it easier I want to substitute the compressor that is normally connected to the inverter module for a spare motor I have so that I can set the inverter module up inside on a bench (it reports a fault if nothing is connected to it's outputs).
The compressor is a Mitsubishi TNB220FLHMC; 3 phase, 38-200v, 20-220Hz and I've measured the winding resistances, it is ~1.1 ohm between each.
The candidate motor is a 3HP, 415v, 50Hz induction motor from an wood lathe. It measures ~5.5ohms between each winding.
Will it work or am I likely to damage either the inverter or motor? I don't expect to run the motor for more than about 30 seconds at a time.
Alternatively is there something else that I could use in place of the compressor?
