Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
MOSFET identify / substitute?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: MOSFET identify / substitute? (Read 462 times)
ssashton
Regular Contributor
Country:
on:
April 22, 2022, 12:30:54 pm »
I have some stepper motor drivers which were sold as supporting 60V rails. I need more but they are not sold anymore. There is another that uses the same driver chip TMC2160 but has a lower voltage rating. It seems to me the main reason is probably just the choice of output mosfets.
The mosfet used on the 60V version is SMD and labelled 14006NH
The mosfets on the lower rated device are WSP4984 -
https://embeddedtronicsblog.wordpress.com/2020/06/24/tmc2160/
Can anyone identify the 14006NH device so I can confirm it's voltage rating and second, could I get some pin compatible suggestions to up-rate the WSP4984 to 60V capable?
Logged
ssashton
Regular Contributor
Country:
Re: MOSFET identify / substitute?
Reply #1 on:
April 22, 2022, 12:43:43 pm »
Never mind everybody, I found an alternative product!
Logged
wraper
Supporter
Country:
Reply #2 on:
April 22, 2022, 12:44:35 pm »
https://www.mouser.com/datasheet/2/408/TPN14006NH_datasheet_en_20140107-1140146.pdf
60V rating is quite optimistic considering that max voltage for MOSFET is 60V.
Logged
ssashton
Regular Contributor
Country:
Reply #3 on:
April 22, 2022, 12:52:09 pm »
Thank you!
Will the fact it's switching inductive loads be related to the VDSS, or is it really just about rail voltage?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
