the NFC tags tend to use 13.56MHz, generally produced by mifare and using there standard, if your reader supports that, then it should work,
Just kind of hoping that it doesn't just scrape the UID for a door system... these types of tags can be programmed with key strings secured by actually block keys, (practically every NFC tag out there is reprogrammable)
