Author Topic: Enterance exam question  (Read 1488 times)
Offline eripahaTopic starter
« on: May 18, 2016, 02:24:57 pm »
I did a entrance exam that had following question. Calculate Vcc when VL=6.5volts,  R1 = 2k, R2 =4k, RL 650, c1 = 3.2mF. Circuit has been powered up for a long time.
they some how get over 20volts.... wtf is going on?
What they got
« Last Edit: May 18, 2016, 02:26:49 pm by eripaha »
Offline Skimask
Re: Enterance exam question
« Reply #1 on: May 18, 2016, 02:34:05 pm »
And?
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Online Ian.M
« Reply #2 on: May 18, 2016, 02:40:49 pm »
Treating it as a potential divider gives a divider ratio of  0.65/(0.65+4/3) or 0.3277.   Multiplying by the result above (before rounding) gives 6.5V.   So yes, fractionally under 20V is the correct answer.
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: May 18, 2016, 02:52:00 pm »
The decoy capacitor surely put people on the wrong track.
