Sorry to bother you but there's still one thing that been poundering about in the back of my head.
Am I correct in saying the frequency am trying to measure for my lc meter is called the resonant frequency?
I think that should be right.
Whatever it's called according to my calculations when am measuring a 10nH inductor with the 1000pF calibration capacitor then the
frequency I'll be measuring is 50MHz. That many mangitudes higher than the claimed 8MHz on the web page you linked to.
That doesn't sound right, I think 50 MHz is way to high frequency to measure with something that only has a 4 MHz clock. Anyone else have some thoughts on this?
I saw a similar project use a 74HC191 logic chip, would this do the job for me? If not could you recommend me a cheap alternative
It's possible to design a LC meter using logic chips, however i think you can just forget about measuring 50 MHz with that one to. The datasheet
http://www.nxp.com/documents/data_sheet/74HC_HCT191_CNV.pdf say maximum frequency is 36 MHz.
I'm not an expert on these designs, but I doubt the PIC @ 4MHz can handle 10 times higher frequency than the Atmega @ 16MHz.
It wouldn't surprise me if there was a typo on web page and it should be uH instead of nH. 10 uH would give you ~1.6 MHz, which seems like a more realistic frequency.
That said, I'm no expert. I just wanted to point you in the general direction of the Arduino frequency counter. You should probably look at the different circuits and compare what the difference is.
