Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
NPN transistor base resistor voltage spikes?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: NPN transistor base resistor voltage spikes? (Read 2927 times)
Agony
Contributor
Country:
on:
April 25, 2013, 12:44:49 am »
Run the simulation and noticedthe unusual voltage spike inbetween theresistor and base.
Would it be a bleedthrough from the 12V on collector?
Logged
Bitcoin GHAS renting and 0% fee stratum mining.
https://cex.io/r/0/condemned/0/
MikeK
Super Contributor
Country:
Re: NPN transistor base resistor voltage spikes?
Reply #1 on:
April 25, 2013, 02:52:21 am »
Your third attachment is empty.
Logged
Agony
Contributor
Country:
Reply #2 on:
April 25, 2013, 01:36:00 pm »
weird... this should do then:
Last Edit: April 26, 2013, 12:44:59 am by Agony
Logged
Agony
Contributor
Country:
Reply #3 on:
April 26, 2013, 12:45:14 am »
Could it be a simulation error or a kind of inductive voltage spike?
Alltho its within limits and wouldnt damage the transistor, and the extra current it would let through wouldnt be a problem in current case - its still unwanted.
How would you go about smoothing it out?
Was thinking of a zener with a low breakdown voltage (in that case 0.9V) right inbetween the resistor and base with one end grounded.
So it would ground any spikes.
https://www.circuitlab.com/circuit/p3uvb3/npn-transistor-switch/
Tho that resulted in a waveform that has slightly less voltage at the beginning of each cycle and a spike in current at the end.
Last Edit: April 26, 2013, 01:01:35 am by Agony
Logged
croberts
Regular Contributor
Country:
Reply #4 on:
April 26, 2013, 01:14:33 am »
Hello Agony
I ran the simulation and do not see the spikes. I attached the image.
Logged
Agony
Contributor
Country:
Reply #5 on:
April 26, 2013, 02:27:29 pm »
yes, i currently added the D2 zener wit h around 0,9V of breakdown voltage so it grounds the spikes, if you remove/disconnect it, the spikes show up.
Logged
w2aew
Super Contributor
Country:
I usTa cuDnt speL enjinere, noW I aR wuN
Reply #6 on:
April 26, 2013, 02:51:44 pm »
This is most likely a defect in the model for the 2N2222 in the simulator. Models aren't perfect, and some are less perfect than others, especially for modeling non-linear, large-signal behavior.
Logged
YouTube channel:
https://www.youtube.com/w2aew
FAE for Tektronix
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
