so in my example, with the pure sine function, there is zero Q?
OK, what you said, but also better understanding what the I and Q components of a signal are. I can appreciate a negative value of either I and Q functions, so that would make sense in a real world representation. Seems there would be two solutions for it, too, like an image.
In your example, my understanding is that the power supply plays the role of the LO from a quadrature modulator, right?
If so, then you produced just the I component. You didn't produced the other mandatory signal, Q. In order to talk about that corkscrew 3D chart, we need to create the other signal, the delayed I, which is named Q. Without creating Q, the fancy 3D chart doesn't make any sense, the Q projection plane does not exist, and it would be just a 2D chart for a usual sinus curve, not a 3D helicoid.
Let's imagine the following problem: we want to learn about wiring in parallel 2 precharged capacitors, one being twice as big as the first one, each with it's own initial voltage. What would be the final voltage when put in parallel?
And, we found a webpage with complicated charts, and explanations about exponential discharge, and the alternative representation of any e^^x with imaginary numbers, and a bunch of many other very complicated points of view. Another representation of the same problem will be to treat the capacitor as a transmission line, and in this case the voltage will vary in stairs, not continuously, totally confusing, but correct.
In the first place, we don't need all the e^^-t bullshit, or transmission lines, even if all that theory is correct, and sometimes necessary. To understand our final voltage problem, all we need to know is the conservation of charges and the definitions of capacitance, so why to talk about exponential functions, or transmission lines in a webpage called "Parallel capacitor's voltage for dummies".
Now, the initial question from the SDR "What would be Q, then?", translated to our capacitors voltage problem will become something like: "I have only one capacitor, what would be the the second capacitor?", or "I have one capacitor, does that means that the other one has 0 Farads?".
Long story short, for me it was very useful to have an experimental approach in order to build some practical understanding. Once I arrived myself at the same conclusion as the one from the minute 8:13 in the posted video, it all started to make sense. Only afterwards I started to match that understanding with the many possible approaches for a quadrature mixer, and the crazy math and charts corresponding to them. From here, the complexity can escalate pretty fast, especially when the quadrature modulator is used for digital communications.
I did it like that:
- generate the fixed signals I and Q with the soundcard, using a free programs named "Soundcard Scope".
- use the line out Left and Right channels as I and Q from the LO.
- put an external 10K volume potentiometer on each Left and Right line out. These 2 potentiometers are our multipliers from the quadrature modulator block diagram. The cursor position will represent mI(t) and mQ(t), and the potentiometers cursor's voltages will be I(t) and Q(t).
- from each cursor of the 2 potentiometers put a series 100K resistor, then tie the other end of the resistors together, at the tip of the oscilloscope probe. The 2 resistors will be our additive mixer for I(t) and Q(t), and the tip of the probe will be Ant(t).
- synchronize the oscilloscope with the generated I
- play with both potentiometers by moving both cursors at once, and observe how the amplitude of the Ant(t) can be changed from the potentiometers. Nothing new here. This would be amplitude modulation.
- now turn one potentiometer in one direction, and the other in the oposite directions. Let's disregard the amplitude of Ant(t), and pay attention only to the phase of Ant(t) relative to I. Notice that we can change the phase of the Ant(t) relative to the I signal without altering the phase of the I or Q from the LO! That means we can have phase modulation too, not only amplitude modulation. It all depends of how the mI(t) and mQ(t) are changing relative to each other.
- phase modulation with a continuously increasing phase shift is the same as a frequency modulation, so by carefully varying mI(t) and mQ(t) ratios, we can have any kind of modulation: AM, PM or FM.
Until now, all the experiments were made thinking only about time domain. Only after building a minimal grasp for what happens in the time domain, I started to look at the same signals in the frequency domain, and build from there.
