if you want to learn a lot of "whys" then they have more complicated kits on that site, including kits with pre-amps built in (for the same or about the same price). the kit i linked is VERY simple. not much to lurn from that one, it was just the first one i came across that met your requirements.
i definitely think you'll be satisfied with a kit as a starting point. even the more complicated designs will be ok as you don't have to fully understand them to assemble a working unit.
-sj
