Hi - from one of Dave's videos (on Zener diodes) I don't understand why substituting a 1K ohm resistor for a smaller, 100 ohm resistor, changes the curve?
Actually I am not sure why the curve is not as sharp in the first place.
It looks to me like a phase shift with the larger resistor, and less of a phase shift with the smaller resistor?
Hi there,
One thing you dont show is the TIME scale, so we dont have all the information we need to make a good guess.
I tend to agree with the equivalent capacitance ideas posted elsewhere in this thread, but seeing the time scale for both waves would help a lot.
The equation for a resistor charging a capacitor when the capacitor has zero volts across it to begin with is:
Vc=Vcc*(1-e^(-t/RC))
where RC=R*C.
Using that equation you could try different capacitances and try to mimic the waves you are seeing by changing only the resistor by 10 fold.
If you do that you will see the waves look like in the attachment. Note you need to keep the time scale set the same for both waves on the scope to see them compared like this. This is what you get when you change the resistor value 10 fold. Ignore the axis scales as this is a normalized comparison. You will see slightly different waves because there is a limiting zener too, but the comparison should be about the same.
