Electronics => Beginners => Topic started by: LooseJunkHater on April 02, 2021, 10:08:58 pm
Seriously, I want to pull my hair out. With [this](https://ibb.co/80n1knK (https://ibb.co/80n1knK)) wiring of my LM317, feeding in 12V, I get ~10V at the output tab! With [this](https://www.st.com/en/power-management/lm317.html (https://www.st.com/en/power-management/lm317.html)) calculator, I should be getting ~5V!
I'm so frustrated trying to get this to work. Please help.
Edit: I've also used 2 different LM317's (both branded ST), so I don't think it's a faulty part. I think I'm just being stupid and wiring it wrong, and it's so frustrating.
Something is wrong. If you have 10V instead of 5V, then there is a broken wire or broken contact.
First picture is unclear. Is resistor 240 R - a potentiometer?
700/240 R resistors must give 4.9VDC at the output, if everythyng is ok.
How it comes that a wire to 700 Ohm resistor is going from the middle of 240 Ohm resistor?
Here's another image of it [dead-bug style](https://ibb.co/sjX9hKZ)
Hopefully this slightly clears up what I'm talking about.
I'm glad I'm somehow doing the circuit wrong!
Edit: 12V Pos + Neg is being fed into both legs of the capacitor
You connected 680 Ohm resistor from output pin to GND, why do you expect it to work?
First leg must has both two resistors connected, but not one.
I'm a bit confused. Sp
Attach the 680 between adjust and output. Attach the 220 between adjust and ground.
WOOPS. Wow that was a silly mistake. Now it works and produces ~5.1V on both resistors.
Thanks for the help! Solved!
Vice versa?
Vice versa?
Possibly ;) Good catch.
What's the deal here? It's a standard jellyfish part!
