Author Topic: :: does element14 query always crash? (solved)  (Read 1736 times)
Offline 3roomlab
  • can you tell me how to cal sesame street meter?
« on: February 23, 2015, 11:51:36 am »
as it always happens for me ... i wonder
(solved : using separate browser (in my case : opera) slight java glitch. as it happens, the older opera 11.xx seem to be faster than firefox and chrome)
« Last Edit: February 24, 2015, 02:02:40 pm by 3roomlab »
Their marketted 1ppm is better than his 1ppm because their charts have color.
Offline matseng
    • My Github
Re: :: does element14 query always crash?
« Reply #1 on: February 23, 2015, 12:35:00 pm »
Can't recall that I've ever seen that. I use the Malaysian version of E14, but my guess is that it shares exactly the same codebase as the Singapore version.
A tip that might come in handy- I've setup "E" as a Search Engine shortcut in Chrome to search in element14.  This is the URL I'm using:
http://my.element14.com/webapp/wcs/stores/servlet/Search?catalogId=15001&langId=83&storeId=10188&gs=true&st=%s
It probably needs some more adjustments in addition to change the "my" to something else, but I suppose that it would be easy to figure out by looking at the URL after a normal direct search on the site.
Offline David_AVD
« Reply #2 on: February 23, 2015, 09:20:47 pm »
Do you have cookies enabled for E14 ?
Some web sites will crash in spectacular ways when cookies are disabled.
Offline 3roomlab
« Reply #3 on: February 24, 2015, 05:41:41 am »
i see, snooping cookie munsters ! thanks
Offline adam1213
« Reply #4 on: February 24, 2015, 11:29:01 am »
this is an issue with element 14's website. Each time you visit a page element 145 adds the information on the page you have visited to a cookie. Eventually the cookie gets long enough that the request is too long. Solution: buy from another vendor / get element 14 to fix there site / clear the cookie manually. Note the key that gets long is likely bnTrail
« Last Edit: February 24, 2015, 11:32:34 am by adam1213 »
Offline 3roomlab
« Reply #5 on: February 24, 2015, 11:32:34 am »
yea, im quite used to it crashing.
it normally happens after about 10 steps into a detailed item search/filtering  :-DD
edit :: i think i will do an experiment, i will install opera browser, and use opera to browse e14 exclusively to see what happens.
Offline adam1213
« Reply #6 on: February 24, 2015, 11:50:38 am »
It will likely work for a while until the cookie gets too big again.
Offline 3roomlab
« Reply #7 on: February 24, 2015, 12:15:14 pm »
the java is not happy lol
