Author Topic: Can Spectrum Analysers display phase if they have a Tracking Gen?  (Read 2228 times)
Offline rs20
I feel like this is a really n00bish question, hence the beginners section. Whether calculating the properties of a filter by hand, or doing simulations in LTSpice, you can come up with two figures for any given frequency: the gain, and the phase change (I've even forgotten the proper term for this).
If I build up that same filter in real life, and hook it up to, say, a Rigol DSA815-TG, can it show me the frequency vs phase change graph (as opposed to the standard frequency vs gain graph)? Or does it have to be a vector signal[/network] analyser for it to have that ability?
« Last Edit: February 23, 2015, 03:41:04 am by rs20 »
Offline w2aew
    • My YouTube Channel
Re: Can Spectrum Analysers display phase if they have a Tracking Gen?
« Reply #1 on: February 23, 2015, 03:43:59 am »
It generally has to be a vector network analyzer. The DSA-815-TG and most all SAs do not have phase coherent receivers.
FAE for Tektronix
Offline rs20
« Reply #2 on: February 24, 2015, 09:27:55 am »
Thanks! So if I have a control loop sitting in front of me, and I want to get a Bode plot / check the phase margin of that control loop, what's the standard way to do this if a network analyser can't do it (by itself)? I'd be surprised if a network analyser is the standard method to do that; those things seem to go up to GHz and cost megabucks. Obviously I'm missing something.
Online Howardlong
« Reply #3 on: February 24, 2015, 10:02:44 am »
What frequency are you interested in?
You can measure phase shift and thus margin with a signal generator and a scope assuming that the bandwidth of the scope is sufficient. Doing a Bode plot for both gain and phase can also be done on a scope and signal generator too but it'll take some time to do it manually.
As a minor aside, for lower frequencies the Analog Discovery may do what you want, it will do mag and phase to a few MHz.
Offline rs20
« Reply #4 on: February 24, 2015, 10:21:07 am »
Probably only a few MHz, yes. But the average lab wouldn't have an Analog Discovery, and doing the sweep by hand seems laborious. I guess I'm just overestimating the need for Bode plots of real life circuits; I suppose I had just invalidly assumed that it was standard practice to test this sort of thing.
Offline jpb
« Reply #5 on: February 24, 2015, 12:29:56 pm »
It depends how often the job needed doing. If it was frequently then it would probably be worth writing some software to automate a function generator and a scope.
Also high end counters can measure phase, so if you had a two channel function generator with one output going to the filter and the other being a reference bypassing it and attached them to the two channels of a counter that measures phase you could then get a phase plot fairly easily (I can't vouch for this as my counter is a cheap model that doesn't but the high end ones do and also can display both phase and frequency I think.) You could do it with one channel of course and just split the signal before the filter.
PS : the AD8302 measures gain and phase and you can buy a development board for it.
« Last Edit: February 24, 2015, 01:05:02 pm by jpb »
