What do you mean? For Phil's design I just thought taking the current design, and making a GND pour on top and bottom layer. That takes 5 seconds at most?
(there are already vias stitching his two internal GND planes which will stich the ones on the top and bottom - maybe one can spend 5 minutes adding a few more).
Ah, but will the stitches be random compared to the added ground fills? Will they happen to capture inside corners (peninsulas), long spans, islands? Stitching inner copper is easy, nothing's routed there (assuming, anyway; haven't watched the video, if you have some highlights to check out?). Which, is an odd thing to do for 4 layers, but I'm guessing he chose to route power because it's just a connector board?
Remember the coupling. By adding copper, you're under some obligation to pin it down as well, lest you make resonators that couple to traces, and then modify the signal quality and EMC of the design.
Say you have two traces running between two connectors opposed on the board, left to right say. They're parallel, separated by pin pitch say 0.1", and you pour ground over them. Ground fills inbetween, and connects around the pads -- there's plenty of space between the pads to connect back to the bulk of the GND. But you're left with this extra-wide trace of GND, between the two traces. At low frequencies, that's fine, good even as it shunts E-field, reducing capacitive coupling between traces. (Which might be useful for a 2-layer board, and might be negligible for 4-layer because the trace separation is many times the height above inner plane.)
At high frequencies, on par with the length of the traces, however, you get, well, whatever impedance is connected at either end, and transmission line lengths spanning the middle. Which are coupled loosely to a third lower-Z TL inbetween. If the connectors are terminated, then we don't need to worry about SWR on the traces and the only interesting part will be resonance of the GND trace, which will be a 1/2 wave (shorted both ends) stub. Or folded dipole if you like. And being that it's relatively wide, it should have relatively strong coupling to radiation. And being that it's edge coupled, it should have a fairly high Q, i.e. gently driven by the surrounding traces. So if one of those traces is excited with, let's say this board is 4" wide so the 1/2 wave mode is resonant around 1.05GHz -- there's still more considerations to go into this, but it may indeed happen that there's a tall, narrow peak in emissions around this frequency, or it fails susceptibility around this frequency. This also causes a notch to the frequency response along a given trace, and a peak to the coupling between traces -- the high Q of the 1/2 wave stub resonator allows it to couple much more strongly, near resonance, into those traces.
Whereas with stitching vias, this errant GND trace can be stuck down until, say, 20GHz+ which shouldn't be relevant at all to a circuit made on FR4.
Maybe this isn't the greatest example, because most people don't run high-speed digital comms over 0.1" headers, and even when they do, they don't separate the traces to allow GND to fill between them (e.g. LVDS pairs). (And even then, a trace between a differential pair sees only common mode, which should be small from such sources.) But for illustration purposes, any island, peninsula, isthmus, trace -- can have some impedance at high frequencies, affecting signal quality somewhat, or at worst, becoming an antenna at some resonant frequency. Those frequencies will usually be high enough you won't excite them with say CMOS logic signals, but various kinds of LVDS are expected to run that fast. (And notice that differential trace pairs aren't twisted; they couple asymmetrically into whatever's beside them. So an LVDS pair routed beside a poorly-pinned GND structure can trigger such behavior. Granted it's even weaker, it's only coupling into half the differential pair -- the nearest trace -- but that's still something.)
So that's why I don't like to pour GND indiscriminately: it takes time to stitch, while giving very little improvement.
And keep in mind the knock-on costs as well: it's one thing to pour and stitch an existing design. You might not spot all the points of interest (inside corners etc.), but you can do a pretty good job of it. Now change the design, move around a bunch of components and traces. Will you remember to inspect all the changed areas? As traces cut and reroute, the pour's topology changes; you may need* to remove redundant vias, and add more in somewhat unexpected areas. Basically, you're spending a lot of time, AGAIN, verifying the stitching, after already doing it once. And again and again as revs accumulate.
*"Need" in the sense of keeping it consistent. There's very little actual cost of extra vias stitching across a 3-layer-GND situation like this, but do mind they still cause voids in the VCC plane. And I suppose maybe you'll save a few millicents in production, but unless you're getting really carried away I don't think they really care on a proto basis.
But if I summarize your answer to my question (which was "is there any reasons not to have a GND plane"):
* it can be a lot of work for very little effect (especially for 4-layer design with inner GND pane already)
* but no other reason (i.e. nothing "bad" will ever happen from too much GND)
can you confirm?
And what about for a 2-layer design?
For 2-layer boards, it is the ONLY way to get a plane. So it is, for almost all intents and purposes, mandatory!
Consider this rule of thumb: you want about half the layers dedicated to planes.
On 4-layer, with SMT components filling one or both sides, routing naturally is drawn to those layers. Great. (Also, maybe you could do bottom plane with top-only placement, but then the copper density would be unbalanced, which may cause warpage.) So, inner planes are a natural fit, and good symmetry, and there's two of them so you can do GND and VCC and save a lot of routing trouble as well as get good grounding and supply impedance.
And so on for higher layers. Like for 6, maybe you're still fine with the two planes, and just want to add two layers of routing, sandwiched neatly between planes, well shielded. Or do the no-outer-routing design, all connections by vias to inner layers. That should be enough to do the job pretty easily. And there's not really a balanced way to do 3 planes over 6 layers, and 4 would be too many (but, again, you can pour and stitch outer copper if you like, and if you have the room to stitch it). For multiples of 4, half and half planes and signals works out well. And of those planes, probably about half should be GND, and the rest can be VCCs.
But what do you do for fewer layers? If you're doing single side placement, you can place top, pour bottom, and use a minimum of routing on the bottom -- only just enough to cross traces over where needed. Copper density won't match real well though. So you might fill the top with GND pour after all, and stitch it, and while that's going on, you save some GND routing which is nice I guess. You have no room for pouring VCC -- it must be routed.
Then, say layer you need to move some components to the bottom side, or add more and you're out of space on top. Well, if you can find some blank area to place them -- sure. Now you have no choice but to slice up the bottom pour, and the design starts to look symmetrical, in that top and bottom GNDs both have a lot of voids. As long as those voids don't overlap (there's always GND above or below a component or trace), and where they are, they are small and the perimeter is kept minimal and well stitched (i.e.: trace intersections must void through both GNDs, so stitch around the intersection with at least 3 vias to keep the resulting thru-void minimal), you'll still have good grounding (as good as can be had in this format, anyway).
Basically what ends up happening is, because there's GND top and bottom, but partial, but supporting each other, it's like creating one average plane in the middle of the board. So you've effectively achieved your "half layers GND" quota, while routing/placing on both sides.
Mind, you don't actually get very much density from both sided placement, on a 2-layer board: you require GND pour under/over every component and trace/bus, so components tend to alternate sides, and buses tend to swirl around them, connecting radially and avoiding tangentially around any given area. (If you can manage a coherent directional bias over the whole design, that's fine -- i.e. top vertical, bottom horizontal. Which is also easy to tell the autorouter to do, and that's an easy way to get a starting route to clean up. What you'll tend to find, in more optimized layouts, is a swirl of traces around major components, as many connections come into them, and others must circle around. There's a certain intersecting-complementary-field-lines quality to it, or a sort of van Gogh style if you like.) You need probably about the same board area dedicated to routing as component footprints themselves. And that sounds suspiciously like the case for single-side placement, so indeed you don't usually gain much from two-sided placement on 2-layer designs. That said, small/incidental components like termination/bias resistors, bypass caps, etc. can be gainfully placed on the bottom, under respective (larger) components, saving top-side placement and routing area while having very little impact on bottom-side GND fill.
As example, here's a render of one of my densest 2-layer builds:
Schematic:
https://www.seventransistorlabs.com/Images/LimitingFuseSch.pngAs you can see, it's mostly top-side placement and routing, and mostly works out pretty well, except for the tangle of bottom routing beside the STOP button / under Q6 area. And you can see, well, they're hard to see with tenting, but, there's plenty of via stitching still -- in strategic areas only, no room for a stitching grid -- near GND pads, inside corners, high current paths, and there's even room for a thermal pour under the power transistor.
