What happens when two diodes are in parallel? if this is a bad idea, why exists shotkky diodes with common cathode? (i. e. to220 package).
As others have said, some diodes do not do well in parallel, although we do find this arrangement from time to time in commercial equipment.
The problem is with many silicon diodes the characteristic voltage drop goes down with higher temperatures, so if one heats up before the other that one diode could start to take up the whole current load. That would eventually blow the diode out. Luckily, there is some other resistance that will increase as the temperature goes up, but it's not enough to compensate for the decrease in characteristic voltage. This is why some good designs include a small value resistor in series with each diode so that they can share the current better.
The imbalance can be small or large, depending on the type of diodes, their similarities, and how close they are to each other when mounted. This means it takes a little more effort to use two diodes in parallel successfully. There are also designs that use more than two in parallel, even four diodes in parallel. To get this right you have to understand the exact nature of diodes as to how they respond to voltage and current and temperature. if you are not sure about that, then you should try to use just one diode, or use two and test the hell out of it, but you'd have to test on a piece-by-piece basis because each diode could be a little different.
Diodes that have a common cathode or common anode are not made to be used in parallel, more or less. They would probably do better than two random single diodes though because the internal diodes would be very well coupled thermally, which means they would have almost the same temperature all the time. They are not made for that reason though they are made to make it a little easier to mount diodes that have to be connected together, and this application would often be a rectifier with a center tapped transformer which needs only two diodes and one lead from each has to be connected together just like that.
