Author Topic: Can you help me figure out what this component is?  (Read 1543 times)
Offline cncmanTopic starter
« on: September 08, 2019, 09:05:39 pm »
Hi all,
Newbie question. I need to replace a broken component from a momentary remote push button. The component has a dark (chocolate) brown case, looks like a resistor, measures 200 Ohm across the leads, and has a color code that doesn't match the resistor chart. Red, Black, Brown, Red, then a wider White band.
Thanks for the help,
Ben
Offline Buriedcode
Re: Can you help me figure out what this component is?
« Reply #1 on: September 08, 2019, 09:10:30 pm »
A picture would be helpful.  The colours red, black, brown do indicate 200ohms (2, 0, 1*10 multiplier).  And resistors do come in different case colours with brown being common in slightly older equipment.
So I'll say 90% sure its a 200ohm resistor, but the wattage depends on the size and to some extend to type (carbon, wirewound, metal film etc..).
With that said - how did you measure it if its broken?  Was one of the leads broken or was it snapped in half?
« Reply #2 on: September 08, 2019, 10:30:10 pm »
One of the leads is broken and not long enough for me to solder.
« Reply #3 on: September 08, 2019, 11:21:50 pm »
I hope these pics are good enough.
Offline tooki
« Reply #4 on: September 09, 2019, 01:14:16 am »
You are joking, right?
You could have cropped off 95% of each image. But it’s so blurry as to add absolutely nothing. Try again, using a better camera or better light, and crop before uploading.
« Last Edit: September 09, 2019, 01:16:45 am by tooki »
Offline mikerj
« Reply #5 on: September 09, 2019, 08:23:12 am »
If the white band is actually silver, then it could be a 200uH inductor though the resistance is very high (probably 10 times higher than I'd expect).
Offline Totalsolutions
« Reply #6 on: September 09, 2019, 10:53:46 am »
Why can’t you solder to that you are in the repair business. Take a suitable sized wire and do it. Issue gone.
Paul
Offline Buriedcode
« Reply #7 on: September 09, 2019, 01:08:11 pm »
It looks a bit like an axial inductor to me.  But again, could still be a resistor, especially as the colour code matches the resistance  Both are plausible in a switch.  I would just solder in a similar sized resistor (can't tell teh size from that pic, nothing to show scale), or two 100ohm ones in series.  If the equipment works, it works, unless there's something funky about the switch gear, like its switching mains, it shouldn't hurt.
But really, more context would be helpful for others - what equipment was this in? (manufacturers, part numbers) and what does this equipment do?
Offline Jwillis
« Reply #8 on: September 09, 2019, 07:50:16 pm »
Just looks like an older Flame-retardant resistor to me .But Buriedcode could be correct as well .The white band could be a custom tolerance.
« Last Edit: September 09, 2019, 08:13:47 pm by Jwillis »
« Reply #9 on: September 10, 2019, 02:57:22 am »
Sorry, I don't have a better camera. The one on my phone is the only one I have right now and my phones get ruined because I work in a machine shop.
I've drawn a schematic of the switch using an online tool. I've drawn the "mystery" component as a resistor. Circuit polarity and voltage is still unknown. It's just a remote Go/Stop Button for a CNC milling machine called a TRAK DPM.
The white band is definitely white
Thanks for being helpful and patient with me.
I just saw a mistake in my schematic. The Cap is actually .1uF
Sorry.
« Last Edit: September 10, 2019, 02:59:20 am by cncman »
Offline Jwillis
« Reply #10 on: September 10, 2019, 06:18:36 am »
Arc suppression? But I thought the resistor should be in series with the cap parallel to switch. :-//
Offline Siwastaja
« Reply #11 on: September 10, 2019, 07:11:28 am »
If the color code says 200 ohms, and it measures exactly 200 ohms, why it would be anything else than a 200 ohm resistor?
The following users thanked this post: Kilrah, Ysjoelfir
Offline mayor
« Reply #12 on: September 10, 2019, 08:49:25 am »
Isn't it just a LP filter used as a switch debounce?
« Reply #13 on: September 10, 2019, 06:13:03 pm »
It must be a resistor.
I was able to check port on the machine and found 5V at 3.43mA.
Offline FreddieChopin
  • Country: ua
« Reply #14 on: September 10, 2019, 07:15:16 pm »
I wonder from what year is that resistor tho. It's perfectly round while most currently made ones are like -OoO- shape (wider at front and rear and thin inside). \$\Omega\$
« Reply #15 on: September 11, 2019, 02:59:04 am »
I'm guessing it's from the mid 90's, or at least that's when the machine it was attached to was made and sold.
The resistor is tiny. About the size of an uncooked grain of rice. Either it was used for its size, or it was cheap surplus at the time.
Offline Jwillis
« Reply #16 on: September 11, 2019, 06:56:36 am »
I found a thread of someone retrofitting a CNC with a similar switch and it turns out that the circuit is the  same as yours and the resistor has a very close value of 220 Ohms.
https://www.cnczone.com/forums/want-to-buy-need-help-/147799-cnc.html hope this helps
« Reply #17 on: September 11, 2019, 08:32:04 pm »
Yup, that will be the same switch. They use it on all prototrak machines.
