Author Topic: Can you take a sine wave to rectifier then easily make into AC  (Read 901 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
« on: September 18, 2018, 12:39:04 am »
For example put 60Hz AC (+0-
through brige rectifier or full wave rectifier so you get a 120 hz signal +0+0+0+
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline IanB
Re: Can you take a sine wave to rectifier then easily make into AC
« Reply #1 on: September 18, 2018, 12:40:59 am »
I don't get it. The sine wave you started with is already AC. Are you trying to double the frequency or something?
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: September 18, 2018, 12:53:27 am »
... put 60Hz AC through brige (sic) rectifier or full wave rectifier so you get a 120 hz signal.
Sure, you will get a 120 Hz signal, but it won't be a sine wave.  :)
