Author Topic: Mystery inductor [SOLVED]  (Read 1485 times)
Offline newbrainTopic starter
« on: February 19, 2018, 03:01:22 pm »
I'll resort to the collective knowledge of the forum.
I've been given some SMD inductors (see bad phone picture, actual size about 2x2x2mm), but I cannot really read the colour code.
Google is not my friend, I was not able to find any similar inductor.
How many bands am I supposed to see?
Two brown - one black - one silver? 11 * 0.01 = 0.11uH? Or what?
Smashing one confirms that they are actually inductors.
Tonight I'll try to see the LC resonant frequency with a known capacitor...
« Last Edit: February 23, 2018, 07:54:43 pm by newbrain »
Offline Belrmar
Re: Mistery inductor
« Reply #1 on: February 19, 2018, 08:18:36 pm »
For this kind of stuff the best way to know a value is the LC resonance, if you are looking for a precise value SMD inductors are not the best they usually come with 20% tolerances, so yes. LC FTW
Re: Mystery inductor
« Reply #2 on: February 19, 2018, 08:22:56 pm »
Thanks,
That's what I plan to do. I also have some with two thin red lines plus the brown one...
It will stay a mystery till tomorrow, though, as I forgot them at work  |O
Edit: Mysspelling in the thread title :-[
« Last Edit: February 19, 2018, 08:25:10 pm by newbrain »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 19, 2018, 10:59:01 pm »
91?  221 (for the other)?
Anyone's guess if that's nH, uH or something else.  Coilcraft parts for example are numbered from a variety of decimals, so you have to look at the datasheet (not that the number is normally printed on the part anyway, so you have to measure anything salvaged).
Seven Transistor Labs, LLC
« Reply #4 on: February 20, 2018, 09:12:19 pm »
Well the are quite small, if they are inductors at all.
With 47nF Fres~=3.6MHz.
So, that would be about 40nH...too close to the self inductance of a few cm of wire to be confident in the result... :-\
Re: Mystery inductor [SOLVED]
« Reply #5 on: February 23, 2018, 07:54:22 pm »
Ok, I made a tighter test rig and got more reasonable results.
They are read from the wide color band, 3 bands only.
Value is in nH.
The one in the photo in the OP is Brown - Gray (or white?) - Black = 18nH
From the first screenshot, still with 47nF ~22nH
The other one Brown - Red - Red = 1200nH
From the second screenshot, 47nF ~ 1300nH
Considering tolerance and parasitic L/C, a good match.
« Last Edit: February 23, 2018, 07:56:18 pm by newbrain »
