I like to know if you think it's possible to use a 4066 to switch at least two different composite video sources.
I've looked around a bit here and elsewhere. Can find a circuit for doing this. Maybe the IC can't do it so well.
Rather than using a relay, is there an elegant electronic solution? It's for surveillance/recording and I don't want a relay operating every three seconds. Prefer not to buy a 'box' solution- rather build myself.
I understand, just like using a hard switch, the video sync would be upset for a moment when switching. But could this device be used to select between two video signals without too much signal degradation?
Do you have any experience with switching video with this device or any others?
