Thank you all for your comments,
Dear Hero999, this is the original board that was shipped in the product so failed resistors were not replaced before. I do not know exactly what caused the failure, but it is likely that general failure reasons like aging, corrosion, fluctuation on the power line or even poor design (although it is a Bosch/Siemens Home Professional product) caused the problem. This is why I am planning to replace them with "better" components.
Dear Audioguru, as I said this is a board that came in a Bosch product, so this is not my design, therefore, I do not know what is going on in the circuit, hence there is no chance of doing "a calculation". The resistors look like 2W job, so the engineer who designed this board thought it was sufficient, maybe it is an acceptable value for 5-year life span, but I hope to use this product for couple of 5 years:) It is possible that the voltage level to exceed 316V as line voltage here is 220Vrms. My assumption on their values solely based on their color codes which I cannot tell for sure.
Dear MarkF, I am confident that the first ring is brown, but I cannot tell if the last ring is yellow or gold, that is why I am asking for help:)
