That high-capacitance SMT ceramic is X5R dielectric, so if you use it you want the input impedance of the next stage to be large enough that there will be negligible AC voltage across the capacitor at low frequencies to minimize non-linearity problems (hence the need for a high capacitance value). Note that Mouser does not stock that particular part number (factory order minimum 200 k parts !).
The emitter resistor and coupling capacitor can go at the receiving end of the line, as pointed out by Terry Bites.
If you have room at the receiving end, consider using a film capacitor instead.
Another reason to use an unexpectedly large coupling capacitor is to reduce the noise of the next stage due to its equivalent input current noise generator (especially if the next stage is a BJT) due to the total impedance seen by that stage's input at low frequencies.
