Those are just great simple, compact solutions, than you. If I can find those for cheap it's a done deal
I meant to write "thank you" there, sorry about that.
What are the budget constraints?
Is just just a one off hobby project? Will it be made and sold commercially in small quantities i.e. 5 or so? Or are you going to make 1000s? It's often cheaper to use a module, once the cost of all of the parts, assembly and board space is taken into account.
It's not a commercial product, I'm simply designing the PCB and publishing the gerber files for DIYers, so one-offs typically. Re: budget constraints, well, I don't have a figure in mind, just thought it made sense to use cheap components that are readily available regardless of where you live. The idea of building this thing was posted in a spanish forum by someone else, I believe using components that can only be purchased at mouser or digikey, with shipping costs and all, doesn't make too much sense. There's already a "cheap" solution available here:
http://tagboardeffects.blogspot.com/2014/01/bipolar-voltage-converter.htmlhttps://tagboardeffects.blogspot.com/search?q=3005How about using two 9V batteries or a 12VAC mains adaptor?
A voltage doubler circuit with the 78L08 and 79L08 could provide a +/-8V supply when running off the mains and batteries can give +/-9V directly. It's possible to get sockets with a built-in switch to disconnect the batteries, when running off mains power.
I'm going to put a 9V input for those who want to use the pcb's supply and also V+ and V- inputs for those who prefer to use an external supply like those you suggest, or one of those cheap ebay +15V/-15V converter boards. The pcb is going to be 80x40 mm anyway because it's meant to be fitted in a 1590BB enclosure with pcb mounted pots
like these Since I need those pcb dimensions to get proper spacing between pots (see pic 1 for initial pcb design) I have plenty room to include the optional power supply.
I think I might be able to make it work with +9/-9 but spec said that it wouldn't sound the same as running it at +15/-15:
PS: if you run the opamps from +-9V, as you suggested, the sound would change, not due to headroom or noise considerations but because the opamp itself is operating from lower rails. This effect is not so marked in newer opamps, but more so with the older opamps.
What happened to the LT1615 , LT3460, LT1316 idea?
Going by the prices of those ICs in Mouser, it was probably deemed too expensive. I don't see the point in doing hobby electronics on a shoe string budget. If you really want to save money, there's plenty of cheap junk available.
Point taken. But it's not just about the money, smd components complicate things for DIYers.
