Dear all,
I am trying to make a new battery pack for a Makita drill, going from a 6 cells Ni-MH (or Ni-Cad in origin) 7,2V to a two cell lithium 7,4 V.
I have enclosed, in the original battery package, two "litokala HG2 18650" cells (3000mAh battery with 20A discharge current) connected to a 20A BMS for 2 cells, that has input and output in common, but I think the BMS is cutting the power when using the battery in the drill.
I can't use the battery for more than one activation, and in this first shot the motor rotates well. At the second button press, the battery seems to be instantly discharged, the motor moves a little then stops.
If I recharge the battery for a minute, then I can start the drill again, but only for one time as before.
I think that this behaviour comes from the BMS.
Is it possible that the initial spike of current is higher than the 20A permitted by the BMS?
Is there any workaround I can use to overcome this limitation (apart getting a new BMS with a higher output current, that seems non-existent for 2 cells)?
Thanks in advance.
Lorenzo
