Hi all,
First, thank you for this wonderful resource and your willingness to help.
I am clearly a beginner and had minimal electrical engineering training many years ago in college (meaning I'm not an electrical engineer). I am attempting to build a capacitor leakage tester, the Amateur Wireless Association's design
https://www.antiquewireless.org/homepage/pcb-item-4/. I have purchased their PCB. I saw YouTuber xraytonyb's build of their project and really liked his modification. The original design just has the metering through a DMM or Analog meter that you attach to the circuit. Xraytonyb's modification added a large analog volt meter, used to determine the leakage current, and a digital volt meter to determine the voltage across the DUT.
I understand the logic (or math) behind the need for a buffer circuit so the analog meter's low resistance doesn't load the capacitance tester circuit and have modified the design of xraytonyb's buffer. His design used a +/-9V VCC for his op amp because it was something he already had on hand from a previous build. Since I didn't have any -9V regulators, but had 5, 6 and 12 V +/- regulators in my parts bin, I modified the design to take a +/- 12V VCC. I have drawn up a schematic in KiCad for both the power supply and buffer circuits. I think, based upon the rotary switch I've ordered, that I can mount the entire small board to the front panel of the case, so I kept the power supply board separate, which I also would imagine is a good practice anyway.
I have attached screen shots of the schematics I drew up, as well as a picture of the AWA's PCB page and xraytony's finished leakage tester.
I intend to purchase a Jameco Valuepro 102111-R Power Transformer, 24 VCT/1A, 115/230 Vac transformer. For the analog meter, I am planning on the Adafruit 5V large panel meter. And the digital meter is an inexpensive Amazon buy - YB4835VA Digital Voltmeter Ammeter DC 600V 100A.
Would this transformer be adequate to power the buffer circuit and also provide a +5VDC output to the digital meter? The UA741 op amp output supply current is listed at 3.3 mA full range and the digital meter says 20mA for regular operation or 200mA isolated operation. The transformer specs it is 1A, so that should plenty of extra supply to account for any losses?
The capacitance leakage tester circuit is powered separately by a Hammond 229A230 as spec'd out in their build sheet. Because I'm dealing with mains AC I don't want to do anything dangerous or hazardous. They provide no schematics, but a BOM which does not include the AC parts. I know I'll need an IEC connector, a power switch, a fuse and a varistor for the mains input. Is this the sort of MOV i should use?
https://www.mouser.com/ProductDetail/YAGEO/361KD20?qs=PzGy0jfpSMuY6yzw3dD%2FOw%3D%3D Soldered across the L and N post fuse?
If I used a fused switched inlet like this?
https://www.mouser.com/ProductDetail/Bulgin/BZH01-Z0000-10?qs=klolToFEUMVTQKfIDu%2FEyQ%3D%3DDo you see any problems with my choices (other than a novice dealing with mains voltages)? Thank you for your input.
