Author Topic: what sensor is used in this video  (Read 1393 times)
Offline Vindhyachal.takniki
« on: September 01, 2016, 06:41:11 pm »
Below is link for video, which sensor is used here which can detect the glove/ball/hand touch?
Offline Dave
  • Country: si
  • I like to measure things.
Re: what sensor is used in this video
« Reply #1 on: September 02, 2016, 12:33:10 am »
You could have an IR emitter inside and measure how much light bounces back. If the value suddenly increases, you know that something is in front of it. You could even reuse the LED that you have for lighting the whole dot as the receiver.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #2 on: September 02, 2016, 02:14:20 pm »
Will resistive touch work. Although person also hit it with glove.
SO I dont know it may break? Is there any way it can be made strong enough??
