Author Topic: Capacitor that looks like a resistor?  (Read 15283 times)
Offline SkyfoxTopic starter
« on: February 17, 2018, 09:16:12 pm »
While I'm not a noob when it comes to electronics, this is definitely a beginner question because I've never noticed this before.  Attached is a photo from the motherboard in my Commodore 64.  I have to do some troubleshooting and repairs, and noticed this component.  It looks like a resistor, has colored stripes like a resistor, but has a green body as opposed to the traditional beige of neighboring resistors and is in spot marked for a capacitor.  The service manual indicates this is supposed to be an 82pf cap with 5% tolerance, which the gray-red-black-gold seems to indicate.  I had a very hard time finding consistent color coding charts, at least when it comes to the tolerance.  Some charts show gold at 5% tolerance, and others show no tolerance indication for that color.  I take it the white stripe is supposed to be the voltage rating, but one chart shows that's 3 volts while another chart shows that's 900 volts.  There are a few others like this on the board of various ratings.
Anyway, is this in fact an axial capacitor?  Certain other sources show axial inductors with a green body and stripes like this so I don't know how I'd tell them apart.  And does anyone have a reliable color coding chart for this so I know what the colors in the tolerance and voltage lines are actually supposed to be?  Thanks!
« Last Edit: February 17, 2018, 09:19:00 pm by Skyfox »
Offline Wimberleytech
Re: Capacitor that looks like a resistor?
« Reply #1 on: February 17, 2018, 09:49:24 pm »
Looks like a capacitor according to this schematic.
Offline Nusa
« Reply #2 on: February 17, 2018, 09:55:55 pm »
https://en.wikipedia.org/wiki/Electronic_color_code#Capacitor_color-coding
If that's correct, the white band indicates it met EIA standards.
Offline tigr
  • Country: ua
« Reply #3 on: February 17, 2018, 10:26:35 pm »
There are such capacitors.
Skyfox
Your capacitor is 91pF.
« Last Edit: February 18, 2018, 12:28:54 am by tigr »
The following users thanked this post: s8548a
Online Jwillis
« Reply #4 on: February 17, 2018, 11:29:02 pm »
Axial capacitors.I've see a few of these but never really looked at the construction.Are they a wrapped film or cylindrical?
Offline Neomys Sapiens
« Reply #5 on: February 17, 2018, 11:30:21 pm »
I knew it! Commodore and it's contraptions were foisted upon us by the KGB!
How else could they have known thos capacitors?
Offline tigr
  • Country: ua
« Reply #6 on: February 17, 2018, 11:55:22 pm »
151pF.
« Last Edit: February 18, 2018, 12:31:55 am by tigr »
Offline Brumby
« Reply #7 on: February 18, 2018, 12:51:50 am »
Skyfox
91 pF
or
82 pF
I'm inclined towards 82 pF myself.  For starters the band next to the white is gold - not brown.
« Last Edit: February 18, 2018, 12:56:24 am by Brumby »
Offline tigr
  • Country: ua
« Reply #8 on: February 18, 2018, 01:11:45 am »
Well, if 82pf, then it should have been welded on the contrary. :-//
Online Jwillis
« Reply #9 on: February 18, 2018, 01:19:46 am »
Should read grey,red,black.,gold ,white 82 pf at 5% tolerance.I suspect the white is likely a working voltage rating of 1000v
« Reply #10 on: February 18, 2018, 01:21:08 am »
Come on!!  The red is really just orange that turned kinda red due to age.  The grey  is grey.  That means 83 which is correct because it is C83!!!  :-DD :-DD
OK...the third glass of wine is talking now...
Seriously, the capacitor below it...the 15 pF.  That is shown as 10 pF in the schematic I have.  So, the schematic may not be reliable w/r to values.  I am voting for 82pF.
Online Jwillis
« Reply #11 on: February 18, 2018, 01:25:43 am »
Well since we're both seeing double from excessive amounts of vino,I'll just say good luck. :-DD
Its a 82pf...no really.
The following users thanked this post: Wimberleytech
Offline tigr
  • Country: ua
« Reply #12 on: February 18, 2018, 01:30:59 am »
They soldered on the contrary. There is nothing terrible. The difference is 9pF. :-DD :-DD
The following users thanked this post: Wimberleytech, Burczyk
Offline IanB
« Reply #13 on: February 18, 2018, 01:34:22 am »
There's an easy way to resolve this. Unsolder it from the board and test it with an LCR meter.  ;D
« Reply #14 on: February 18, 2018, 01:48:27 am »
...always somebody like you in the crowd...
Offline Nerull
« Reply #15 on: February 18, 2018, 01:53:04 am »
Never trust an non-polarized component to be in a circuit board in a specific direction.
If that band is gold and not brown, which the shinyness makes me think it almost certainly is, it can only be read one direction. Gold isn't a valid color for the value.
I saw this on a site that sells recapping kits for C64s: "The values originally fitted by Commodore can vary slightly (from their own schematics!). Please check the listed contents of the packs against those on your particular board."
« Last Edit: February 18, 2018, 02:52:12 am by Nerull »
Offline Nerull
« Reply #16 on: February 18, 2018, 02:04:54 am »
I also note that the schematic has two U31s. I wonder if maybe the C64 engineers weren't entirely sober either.
EDIT: Actually, now that I read it closer, they've just split a single chip into separate sections of the schematic so it looks like two chips.
« Last Edit: February 18, 2018, 02:09:30 am by Nerull »
Online Jwillis
« Last Edit: February 18, 2018, 02:25:53 am by Jwillis »
The following users thanked this post: MarkL, Skyfox
Offline Brumby
« Reply #18 on: February 18, 2018, 02:48:11 am »
It really doesn't matter.  I know you and I would mount it to read with the silkscreen, but this obviously isn't being done on this board.  Just take a look at R16 at the bottom right of the photo.
Offline Nusa
« Reply #19 on: February 18, 2018, 03:53:29 am »
Well, looking at this service manual (https://www.retro-kit.co.uk/user/custom/Commodore/C64/manuals/C64C_Service_Manual.pdf), I see a cleaner version of your snip from the schematic on the second page 21(there are two page 21's in a row). However, down on the second page 27(ditto), there's the same circuit showing C83 as 82pf. Page 17 explains there are multiple versions of the C64 boards. Guess which one the OP has?
Online Jwillis
« Reply #20 on: February 18, 2018, 04:51:38 am »
Is there a Prize? C64 version A (CR)
« Last Edit: February 18, 2018, 05:01:07 am by Jwillis »
Offline tigr
  • Country: ua
« Reply #21 on: February 18, 2018, 09:27:38 am »
Here everything is correct.
C624-82pF.
Offline Brumby
« Reply #22 on: February 18, 2018, 02:26:21 pm »
I wouldn't exactly call that "correct".
If someone had done that on a silkscreen for me ... I'd be having words.
« Reply #23 on: February 18, 2018, 03:45:20 pm »
Thanks to JWillis for that chart!  I'll print it out for the wall in the electronics dungeon (my dank basement).  And thanks to everyone for your replies and input.  This means all these years when desoldering components from circuit boards for the parts bin, I've been throwing out capacitors that I thought were faulty resistors.
To reply to other posts here, that band is definitely gold, not brown.  It may not show up very well in the photo but it does appear sparkly.  And since it's supposed to be 82pf at 5% tolerance according to the parts list in the service manual, the sequence of gray-red-black-gold is correct.  And I have to wonder why they'd put a cap rated for 900v on a board that has at most 12v.
Yes, there were multiple versions of the C64 board over the years, and even different schematics for the same board (ie. my board is labeled with artwork/schematic #251137, but the service manual shows schematic #251138 for my particular board).  Considering how many bodge fixes there are all over this board, it's clear they were revising the thing all the time.  Since my board is dated '83, I used the service manual from '85 for simplicity.  I do have the '92 service manual, but the information for my particular board is exactly the same as the '85 manual.
And since this all has been a mere curiosity for the purpose of learning, I'm not about to desolder and remove this cap from the board just to test it in an LCR meter.  However, I do have a scrap board for parts that I could remove that cap from to test.  For science!
Offline vk6zgo
« Reply #24 on: February 19, 2018, 12:08:52 pm »
Not only are there capacitors which look like resistors, there are also resistors which look like capacitors.
One piece of gear had what looked like a small mica cap .
Testing it didn't show it as a capacitor, but as a resistor.
Closer investigation revealed the capacitor we thought it was in other spot on the PCB.
Further tracing found the original device to indeed be a resistor of the previously measured value.
