Author Topic: Python error; 'NoneType' object has no attribute 'after'  (Read 2362 times)
Offline Vindhyachal.taknikiTopic starter
« on: July 11, 2015, 04:57:49 pm »
I got error while coding in python.
Need to print same random value again & again.
from Tkinter import *
import Tkinter
from random import randint
class App1(Tkinter.Tk):
    def __init__(self, master):
        Tkinter.Tk.__init__(self,master)
        self.master = master
        self.label = Label(self , text = "Voltage" , font = ("Helvetica",32))
        self.label.grid(row = 0)
        self.reading_label = Label(self,text = '0.0' , font = ("Helvetica",110))
        self.reading_label.grid(row = 1)
        self.update_reading()
    def update_reading(self):
        value = randint(0,9)
        reading_str = "{:.2f}".format(value)
        self.reading_label.configure(text = reading_str)
        self.master.after(1 , self.update_reading)
root = App1(None)
root.title("Option")
root.geometry("320x240")
root.mainloop()
I gor error message:
Traceback (most recent call last):
File "/voltmeter.py", line 26, in <module>
root = App1(None)
File "/voltmeter.py", line 16, in __init__
File "/voltmeter.py", line 23, in update_reading
AttributeError: 'NoneType' object has no attribute 'after'
Online IanB
Re: Python error; 'NoneType' object has no attribute 'after'
« Reply #1 on: July 11, 2015, 06:25:00 pm »
root = App1(None)
Presumably you have narrowed it down this far?
I don't know enough about what you are doing to say why 'after' is not defined. Where is 'master' defined?
Offline c4757p
  • adieu
« Reply #2 on: July 11, 2015, 07:16:26 pm »
Have you even tried to follow through your code? ???
root = App1(None)     # here None is "master"
    def __init__(self, master):    # you passed in None for master here
        self.master = master       # so now self.master is None
        self.master.after(1 , self.update_reading)    # self.master is still None here...
"'NoneType' object" (None) indeed has no attribute 'after'. You can't say None.after()... You might want to try passing in something other than None...
Offline bson
« Reply #3 on: July 11, 2015, 07:27:38 pm »
tk=Tkinter.Tk()
root=App1(tk)
See:
http://zetcode.com/gui/tkinter/introduction/
BTW, as a convention, 'root' refers to the root window, which is your display background.  It's what's (conceptually) returned by Tk().  Your app is a child of this, and it would make sense to call it something other than 'root'.  Also, as the examples on the link above show it's generally referred to as an application's parent window, so calling it "parent" is the most straightforward (compared to "master").
« Last Edit: July 11, 2015, 07:36:18 pm by bson »
