Author Topic: Capacitor swap  (Read 1183 times)
Offline ZnfrljTopic starter
  • Country: si
Capacitor swap
« on: December 15, 2018, 11:02:54 am »
I am trying to fix a bad Samsung LCD power supply (running on AC 230V mains).
If I swap the bad 100uF 450V cap with a 100uF 400V I have at hand, it should be ok. Right?
The peak AC voltage should not exceed 325V +/- 15V.
Thanks!
« Last Edit: December 15, 2018, 11:08:05 am by Znfrlj »
Online Psi
Re: Capacitor swap
« Reply #1 on: December 15, 2018, 11:37:32 am »
It should be ok just to test with. To see if that's the problem or not.
But once you fix it permanently i would replace with 450V
The following users thanked this post: Znfrlj
  • Country: si
Re: Capacitor swap
« Reply #2 on: December 15, 2018, 12:09:07 pm »
Ok, thanks!
