Author Topic: Capacitors don't work like I thought, please help me understand.  (Read 3757 times)
Offline gilliganTopic starter
Why does this work?
http://tinyurl.com/y679uqr8
Online jpanhalt
Re: Capacitors don't work like I thought, please help me understand.
« Reply #1 on: April 09, 2019, 09:16:38 pm »
What did/didn't you expect it to do?
Offline PartialDischarge
« Reply #2 on: April 09, 2019, 09:17:51 pm »
Not the kind of circuit you’d want to build but, the gate to source connection is also a capacitor, a small one.
In a resistor divider, the large resistor takes most of the voltage, in a capacitive divider, the small cap takes most of it.
The current through the large capacitor is going to be very small but enough to charge the gate up to nearly 5v.
Id recommend you to watch this video which is somewhat related
Offline Wimberleytech
« Reply #3 on: April 10, 2019, 02:18:59 am »
The voltage across a capacitor is
 V= 1/c (integral) i dt
So you reset the capacitor so that it has zero volts across it (zero charge).  In order for the voltage on the capacitor to change there must be a current to charge it according to the equation above.
There IS NO CURRENT PATH.  The input resistance of the mosfet is infinity.  Since no current flows, the voltage across the cap never changes--remains zero volts.  So the Vgs of the mosfet does not change either.
Surprisingly, this is a useful concept--with a few additional components.
« Reply #4 on: April 14, 2019, 08:22:54 pm »
I always assumed that Caps blocked voltage.
So when the switch was opened, after the cap drained then there would not be anything on the gate of the MOSFET.
But it seems like this will just latch the MOSFET open and just run continuously even when removing supply to the Gate.
Offline james_s
« Reply #5 on: April 14, 2019, 08:29:08 pm »
Why would you assume that capacitors block voltage? Capacitors store charge, to store a charge you have to have a complete circuit to put energy into the capacitor and if you want to use that charge you have to have a way of completing a circuit to get the charge out of the capacitor.
Offline alsetalokin4017
« Reply #6 on: April 14, 2019, 08:30:05 pm »
If you want the mosfet to turn off you have to provide a path from Gate to ground somehow, usually through a pulldown resistor.
« Reply #7 on: April 14, 2019, 08:49:17 pm »
"Capacitors are widely used in electronic circuits for blocking direct current while allowing alternating current to pass."
I'm only working with DC, so I assume that it will just not let current pass.  No?
« Reply #8 on: April 14, 2019, 08:50:01 pm »
But now I can't get the gate to open at all. :(
Offline FriedMule
  • Can make even the simplest task look imposible.
« Reply #9 on: April 14, 2019, 09:06:59 pm »
If you think of a cap as a rechargeable battery with a capacity.
It will charge until it is filled and then it stop charging and thereby stop more power going trough, thereby blocking DC.
AC on the other hand keeps charging while positive and discharging while negative, so the cap will never get filled and therefore do AC keep "working".
The cap will try to release it's charge and as soon you turn off the power, the cap will deliver its charge until depleted.
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
The following users thanked this post: gilligan
« Reply #10 on: April 14, 2019, 09:08:06 pm »
What do you mean?
Try this:  http://tinyurl.com/y5w5ybl6
« Last Edit: April 14, 2019, 09:15:11 pm by Wimberleytech »
Offline james_s
« Reply #11 on: April 14, 2019, 09:13:02 pm »
It's a little more complex than that, any time you have a changing voltage you have something like AC. In a steady state, a capacitor will charge up to whatever potential is across it and then it will block the flow of DC once it reaches equilibrium, but then what? In order to do something useful you have to have a way to charge and discharge the capacitor. What are you trying to accomplish? What do you want the mosfet to do?
Offline FriedMule
« Reply #12 on: April 14, 2019, 09:13:37 pm »
If you want the mosfet to turn off you have to provide a path from Gate to ground somehow, usually through a pull down resistor.
An easy way to understand why your circuit is not working, is thinking of power as super lazy. If you follow your path from the battery and to ground / negative, you'll see that the power can run trough your switch via the lower 10K and trough to ground, totally avoiding the obstacle your mosfet and upper 10K is making.
EDIT: Also, if you look at your circuit. You have positive on booth sides of your cap, so nothing is going on there. You only get a flow if you go from positive to negative.
Am I right in guessing that you are trying to make a delay, so when you switch off, the mosfet stays on for a short while longer?
« Last Edit: April 14, 2019, 09:32:30 pm by FriedMule »
Offline FriedMule
« Reply #13 on: April 14, 2019, 09:18:28 pm »
You are perfectly right but I thought that a simply but not totally correct explanation was better, for later to learn more about what is in reallity is going on. Like the flow of electrons, resistance, conductance, heat and much more do in his circuit. :-)
« Reply #14 on: April 14, 2019, 09:43:09 pm »
What do you mean?
Ah, I blew my capacitor and didn't notice... you'd think I'd learn as i've done that a hundred times now. ;)
« Reply #15 on: April 14, 2019, 09:50:52 pm »
Yes, that was the experiment... just trying to wrap my head around components with these little circuits.
The following users thanked this post: chris_leyson
Offline FriedMule
« Reply #16 on: April 14, 2019, 10:40:55 pm »
Okay great.
First do I think that if you have a horizontal positive rail at the top and a horizontal negative ral at the bottom in the start, that will make it a lot easier for you to keep track on what is going on. :-)
If you place the cap across from positive to negative, you do charge the cap up and everything after that, will get the power from either the power supply or the cap.
Try to make a new version thinking of that and show it here, then we'll take from there, until you know how it works:-)
« Reply #17 on: April 15, 2019, 12:42:43 am »
I suggest you get your head around a circuit that does not include a mosfet.  Like this.
http://tinyurl.com/y4zbmqbl
Offline KL27x
« Reply #18 on: April 15, 2019, 05:15:03 am »
In the simulation, do you see DC current passing through the cap?
If you remove the capacitor completely, it should do the same thing. There does not need to be any current between a MOSFET gate and source for the transistor to remain on, indefinitely. When the switch is open, the gate is floating. Whatever charge has last been left on the gate will theoretically remain there, forever, unless the simulation includes the gate leakage of the FET. Maybe I don't understand the simulation, though.
This is one way to test if a signal or logic level FET is working, out of circuit. Take your multimeter and put it on diode test. Put one probe on gate and one on the source. Then lift the probes and change the meter to continuity test; put the probes on source and drain to test continuity. Do the diode test again, but reverse the probes on the gate and source. Then repeat the continuity test. One outcome will show continuity, because the FET gate is saturated. And the other will be negative, because the gate is below threshhold, and the source to drain will be high resistance (or will have a diode drop, if the probes are reversed... still negative continuity test).
In the diode test, there is a voltage (typically about 3V) applied through the probes, but limited to only a small current. This will charge the gate. The charged gate will retain its state long enough for you to do a continuity test, if the FET is out of circuit.
**I bet this is what MasterTech's video demonstrates.
« Last Edit: April 15, 2019, 05:36:54 am by KL27x »
Offline KL27x
« Reply #19 on: April 15, 2019, 05:44:11 am »
In an otherwise great explanation, I would change "current" to "coulombs." The total amount of coulombs or charge that will flow will be small. The current will be relatively high, since there's no impedance or resistance in the circuit. It will flow for only a short duration, though, after the circuit is initially powered on. Think of it as the first quarter of an AC waveform that "passed" through the (initially uncharged, presumably) capacitor, then just got stuck there.
« Last Edit: April 15, 2019, 05:47:39 am by KL27x »
Offline FriedMule
« Reply #20 on: April 15, 2019, 07:02:12 am »
I have tried to make the LED delay, so you can see how it can be done. :-)
The simulated circuit have to charge for a while, because some strange behavior in the simulator.
And for some strange reason, the simulator shows AC animation, while it is DC.
http://tinyurl.com/yx9opv9f
Extra fun: If you place the resistor on the let side of the cap and make it a 10uK, you will get a LED that slowly turns on after you turn the switch on and slowly off again when you switch off.
« Last Edit: April 15, 2019, 07:07:02 am by FriedMule »
« Reply #21 on: April 15, 2019, 12:19:27 pm »
Putting a voltage source directly across a capacitor challenges the simulator.  Must be what is going on.  Normally a switch is modeled with some resistance, but I bet this one is not.  As you can see, putting a very small resistor fixes the animation.
http://tinyurl.com/y2w6g6vk
It is a cute simulator for sure, but not foolproof.
Offline TimFox
« Reply #22 on: April 15, 2019, 06:52:52 pm »
The simple explanation taught me early in my first electronics course was:
A). You can’t change the voltage across a capacitor instantaneously (requires infinite current), and
B). You can’t change the current through an inductor instantaneously (results in infinite voltage).
Offline soldar
« Reply #23 on: April 15, 2019, 07:37:17 pm »
It's called duality.
« Reply #24 on: April 16, 2019, 12:46:49 am »
Yes, I was floating the gate... I knew better than this.
I swear, floating grounds will be the death of me (hopefully not literally ;) ).
