I've been trying for a few days now to get a simple class A amplifier working on a breadboard and I'm not having much luck!
My latest attempt was using the design schematic from this article:
https://www.electronics-tutorials.com/amplifiers/small-signal-amplifiers.htm
I didn't have any 0.83uF capacitors, so used some 1uF electrolytic caps that I had in my stockpile. For some reason that I cannot work out the circuit, when connected up to 12v from my bench supply, pulls 0.0000 amps and seems to do the complete opposite of an amplifier when I connect up some music to it from my cell phones output jack, the volume is greatly diminished as opposed to when I connect it directly to the speaker being used. I've switched out the caps and tried another 2N2222A transistor, but still cannot change the end result.
Can anyone please offer any insight into where I could be going wrong? I'm wondering if the slightly larger or different type of caps is causing an issue, but I cannot see that that would cause a significant problem as even the article mentions that larger value caps and even electrolytic caps could be used. I'm loosing my hair over this one and there isn't much left to go!
Thanks in advance for any help.
Russ.
Post the schematic and maybe few pictures of what have you tried to build.
However, these amplifiers, in the configuration described in the article, are unlikely to be able to drive a regular speaker. A speaker will have too low impedance and present too high load for a transistor in that kind of configuration. If you want to drive a speaker you will need to add a power stage of some sort. These amplifiers are meant to amplify weak signals e.g. in a radio, not to drive a loudspeaker.
The fact that it draws 0A on your power supply possibly indicates that you have something wired wrong. A class A amplifier will draw quite large quiescent current even with no signal present because the transistor needs to biased to be conducting in order to not "chop off" half of the input signal.
However, if you have build the amp in figure 4, that one has quiescent current of about 700uA - unless your power supply has an extremely accurate meter with a low burden voltage, you are very unlikely to be able to measure that. Most supplies don't have better resolution than about 10mA (3 digit displays), with a 4 digit one you could theoretically measure 1mA but this amplifier draws less than that. So it would show as 0 on the PSU meter. Use a multimeter, check the voltages across the resistors and compare with what is on that website instead.
