That is a rather curious value to aim for and with tolerances, it will be a fluke if you got within +/- 1 of your 111 target. If you had a capacitance meter, you might be able to close in on that value by trying the above combinations from your pool of capacitors.
It is not common for someone to aim for such unusual values, especially to the implied accuracy (you want 111nF - not 110nF or 112nF, yes?) - and the question arises: Why do you need to? In general use, capacitors are rarely expected to be that accurate and designs most often treat their specification as "nominal".
This makes us curious as to why you are seeking this value, as there may be better ways to achieve what you are trying to do. If you can show us a circuit diagram, or at least describe your circuit and objective, we could make more informed comment.
