Sorry for the late reply, most of you know how life get from time to time... Anyhow... Yes Hero, I meant to say a gain of "1". I come from the pro audio world, so I think most natively in dB gain in which "O" is equal in to out. I don't see any reason I would ever expect to feed or send voltages over 1VRMS, probably more in the 500mVRMS range. As this is intercom signal and not anything high fidelity, so some restriction of the bandwidth wouldn't be a problem, it might even be a good thing. The plan was to add some low and high pass filters feeding the final stage anyhow to remove some top and bottom end. Jeffrey, I too saw some information on creating a virtual ground to make the circuit more stable. I've attached a screen shot of a circuit snippet from the LM124 data sheet which I am using at the base for my project. Is my understanding correct that this is this a virtual ground referenced circuit?
Thanks!
