I don't agree. On my scope image CH1 ist the SPI Clock, CH2 the SPI Data 0xFF, CH3 the ~CS. I use the SPI Trigger Function with (CLK, MOSI, ~CS, no CLK timeout) for the Dataword 0xFF. As you can see, after the secound byte the Scope triggers. Everything fine. Now I increase the delay a little bit betwenn the two bytes. The scope not tiggering any more.
Is there any timeout?
