Author Topic: PIC microcontroller books/websites for a newbie  (Read 7311 times)
Offline McPeteTopic starter
  • Layout Designer, AKA eCAD monkey
« on: June 27, 2010, 03:21:10 am »
G'day all,
My name is Peter, and I'm a 3rd year apprentice instrument fitter/calibration/electronics tech. I've recently been studying digital electronics as part of my trade course, and I wanted to start to introduce some more advanced components to things I'm designing and building. One of my supervising tradesmen has just finished a filtered voltmeter project, and I'd like to (down the line) modify the design to get a bit more functionality out of it.
To that end, I asked my supervisor to purchase for me, a Microchip PICKit2 with the low pin-count demo board. I'm a bit overwhelmed by the included manual that seems to be written for someone who isn't entirely new to the game.
I've picked up a copy of this book, and I'm starting to read through it, but I was wonder if anyone could suggest other reading material to get me started on my way. Any help would be much appreciated!
Thanks folks!
Peter
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: PIC microcontroller books/websites for a newbie
« Reply #1 on: June 27, 2010, 06:08:27 am »
well you need to decide early what language your planning on. I gave up with assembler and now use basic although I'm told C is trhe way to go. It gets you a level higher and make life much easier while not really loosing on performance. check out www.mikroe.com
also any book about the 16F84 if outdated, that chip is only still around because it was popular, it has since been surpassed many times, for small stuff try the 12F615 for bigger stuff the 16F88.
« Last Edit: June 27, 2010, 06:33:50 am by Simon »
« Reply #2 on: June 27, 2010, 09:15:31 am »
Thanks guys!
Most of the information I'm reading seems to suggest that C is the way to go- it looks as though it applies across most makes and models of Microcontrollers, with some adaptions here and there. I started looking at an assembly language tutorial and it seemed a bit arcane- C looks (to my limited knowledge) to be the good code to get a foothold with.
I'll let you know how I get on!
Offline Simon
  • Global Moderator
« Reply #3 on: June 27, 2010, 10:51:53 am »
you can learn one language that's not assembly and then apply it to any micro, thats how the software mokroe.com supplies works
Offline wd5gnr
« Reply #4 on: June 27, 2010, 03:45:58 pm »
http://www.awce.com/classroom -- some PIC material there as well as other things. Also some older stuff at http://tutor.al-williams.com/.
Depending on the PIC you choose, Forth is a viable choice and there is a tutorial on that last link about it. Not nearly as popular as I would have supposed though (the language, not the tutorial).
Offline Simon
  • Global Moderator
« Reply #5 on: June 27, 2010, 03:47:54 pm »
what sort of thing is it ?
Offline 74HC04
  • Lifetime Electronics Nerd and full-time EE.
« Reply #6 on: June 28, 2010, 06:38:58 am »
Offline Simon
  • Global Moderator
« Reply #7 on: June 28, 2010, 06:56:10 am »
do microchip offer a C compiler with maplab ? what is the best way to get into C (I know some basic)
Offline ThunderSqueak
  • Dont be a freak... dont be a freak... dont be a ..
    • ThunderSqueak!
« Reply #8 on: June 28, 2010, 08:00:37 am »
take a look at http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en535448
and
http://www.htsoft.com/downloads/demos.php
there are links at the bottom for the lite version of the compiler.
« Last Edit: June 28, 2010, 08:12:17 am by ThunderSqueak »
Currently working with non-binary computing, no reason for it... just doing because I can ^^
Offline djsb
« Reply #9 on: June 29, 2010, 10:40:50 am »
Peter anderson has some useful info here
http://www.phanderson.com/
I'm using Lucio Di Jasio's book to learn Microchips C compiler on PIC24 chips on an explorer 16 board.
http://flyingpic24.com/
For a very good set of tutorials try reading some of the back issues (available on cdrom) of EPE mag.
http://www.epemag3.com/
HTH,
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
« Reply #10 on: July 01, 2010, 06:19:17 am »
Hey all,
I've been working through the Gooligum tutorial, and I picked up some PIC12C509s- These are what Jaycar had, rather than the flash version recommended.
The first one I put in the programmer, worked as described- send MCLR high, the LED came on. Send it low, it went out.
Then I tried erasing it and re-writing the program, and I got an error- something about a value not being as expected?
Would swapping the C and F versions be detrimental to the C series PICs?
Thanks!
P.
Offline Simon
  • Global Moderator
« Reply #11 on: July 01, 2010, 06:56:27 am »
err really I can't see the point of "C" pics: you cannot erase them ! once written thats it, they are use and chuck parts. you should use the "F" series, they are identical but are reusable. The only reason for "C" types is if your worried that the code could be lost/erased maybe for a military application ? Really I can't see the point of the "C" series in the comercial/hobbiest environment other than lower costs at a price of never upgrading code
« Reply #12 on: July 01, 2010, 08:55:25 am »
Well there you go! Lesson learnt, no more buying PICs from Jaycar.
Offline Simon
  • Global Moderator
« Reply #13 on: July 01, 2010, 11:41:17 am »
any supplier will sell "C" and "F" it's up to you to know what you need. I'vwe bought from Jaycar and I'm in the UK
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #14 on: July 01, 2010, 12:43:26 pm »
i forgot to mention, that mostly of my valueable reference to program the pic is the datasheet itself. i'll flip it hundrends of time during programming certain pic chip, even right now! on this very time.
for me, i will use F series for development stage, when the firmware is proven correct, the production line will be fitted with the C series, maybe they are cheaper. is it? not sure, just my 2 cnts.
« Last Edit: July 01, 2010, 12:47:12 pm by shafri »
« Reply #15 on: July 02, 2010, 12:25:54 pm »
My trouble was I read from the printed catalogue, which had the listed ZZ8600 as an F version. The on-line catalogue and the item itself was a C series.
Regardless, my next batch will be coming from RS or Farnell.
Offline Simon
  • Global Moderator
« Reply #16 on: July 02, 2010, 12:31:31 pm »
ZZ8600 is not a microchip pic ? you need to check the datasheets before buying
« Reply #17 on: July 02, 2010, 12:34:51 pm »
Sorry, should have said, that's a Jaycar Australia stock code :P It is in fact for a PIC12C509, according to the website... and an SO SMD one at that. They gave me a DIP one when I quoted that number. Curious and curiouser.
Offline Simon
  • Global Moderator
« Reply #18 on: July 02, 2010, 02:02:56 pm »
check you read the description correctly, not all suppliers use the exact picture sometimes this goes for RS and Farnell
