Author Topic: How does a Hall effect transducer work?  (Read 1186 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
« on: August 17, 2015, 06:36:49 pm »
Hi everybody,
How do I set up this to read the current passing  in a wire  troughtout the device.  I put a resistor?
Do I ut a small voltage between the two post of the transducer?
Thanks for your attention
JPD
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline KerryW
Re: How does a Hall effect transducer work?
« Reply #1 on: August 17, 2015, 09:20:45 pm »
That's NOT a Hall effect sensor..  It is basically a transformer secondary.  The wire you pass through the center hole forms the primary.  It will only detect AC current, not DC.
If that is what you want, connect a 50 Ohm resistor between the 2 pins and measure the AC voltage across the resistor.
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
« Reply #2 on: August 17, 2015, 09:27:11 pm »
Ok.  :-+
JPD
