Author Topic: PSU precision requirements  (Read 1706 times)
Offline kt315Topic starter
« on: April 20, 2013, 08:08:21 pm »
There are currently a few threads in the projects section discussing PSU precision or voltage references (with intend to be eventually used within a PSU).
What are the applications that would require sub millivolt precision/resolution from a  lab PSU?
Offline mikes
Re: PSU precision requirements
« Reply #1 on: April 20, 2013, 08:28:03 pm »
Working with thermocouple circuits is an obvious one.
Offline c4757p
  • adieu
« Reply #2 on: April 20, 2013, 08:52:47 pm »
Not a general list of applications, but just on my personal workbench:
I have an ancient Power Designs model with rated 0.1% precision (usually tests around 0.05%) and 1mV resolution + vernier. I use it all the time as a variable reference just for the sake of convenience (e.g. if you're trying to measure the ratio of Vout/Vin, it's nice to be able to just set Vin to exactly 1.000V and have the ratio show up right on the voltmeter display), and I've used it in a pinch to calibrate shitty (analog) meters. I also have made up some bodgey "precision" gear (DC load, etc) that, instead of having a digital input, takes an analog input reference voltage, "borrowing" the precision decade dials for a cheap and convenient way to dial in an exact setting.
« Reply #3 on: April 21, 2013, 02:32:09 am »
It makes sense,  I guess I can see how it can be used as a reference. Thanks.
