I've looked at the service manual, the tape used was 250nWb/m, not 160nWb/m, no surprise you've run out of the adjustment range! 650mV on pin 7 is roughly correct for 250nWb/m DIN level (the accurate figure is 665mV). Use a proper level cassette and it should adjust just fine.
Cheers
Alex
P.S. - you can see from the manual that for 160nWb/m the voltage is 410mV (the accurate figure is 425mV) - it is clear from the level diagram.
Hi Alex and thanks!
That's altered things a bit.
Before i read your post i just checked pin 3 using your dolby tape and got 860mV. Oops.
But what happened to the 580mV you quoted originally? out of interest..
I've scoured the manual but i can't see where they ever mention a 160 or 250nWb/m. What page was it on? I found the level diagram ok.
Head's spinning a bit as this deck is 1978 - i thought that was pre the 250 cal level established in 1981? It also means Gennlab have the wrong information on their page. But i'm sure you're right. It makes sense now, the numbers - it seemed crazy to run out of pot adjustment.
Btw what do you mean by 'the accurate figure'?
Cheers
Tim (thinkchronicity)
