Author Topic: cathode follower outputs 200vdc  (Read 921 times)
Offline ELS122Topic starter
« on: February 02, 2020, 07:47:05 am »
I have a basic triode gain stage going into a cathode follower without a coupling cap and the cathode follower is outputting 200volts? shouldn't it not output dc?
I didn't have the gain stage before and it didn't output dc so  :wtf:
Offline gbaddeley
Re: cathode follower outputs 200vdc
« Reply #1 on: February 02, 2020, 12:00:49 pm »
Under DC static conditions and normal biased operation, the cathode voltage will be more positive than the control grid, by a few volts.  Check the theory of operation of your circuit.
Glenn
The following users thanked this post: ELS122
« Reply #2 on: February 02, 2020, 12:32:33 pm »
so basically I need a coupling cap if I want to connect the cathode to something that needs a clean ac signal?
the theory behind it was really long so I thought that I could just follow the circuit that was shown and it will work.
I guess I'll go read it
« Last Edit: February 02, 2020, 12:36:44 pm by ELS122 »
Offline IvoS
« Reply #3 on: February 02, 2020, 03:00:03 pm »
Post a schematic.
« Reply #4 on: February 02, 2020, 03:03:42 pm »
I know that the first stage is over biased but ehh...
I now added a 68nF couplig cap on the output of the cathode follower cause it was outputing dc
Offline gbaddeley
« Reply #5 on: February 03, 2020, 08:07:47 am »
First stage has no bias arrangement shown. How are you doing it?
What is the load impedance after the 68nF cap? This will determine the low frequency response.
Glenn
« Reply #6 on: February 03, 2020, 10:59:19 am »
I dunno, I just threw it together cause I wanted more gain  :-DD
it was actually the best working circuit I ever built.
but now I am remaking it and doing it "correct" now. or just copying other designs. I really should read more about tubes. well I guess I'll do it when I'll have time.
for now, I'll stick to already made things.
the input impedance should be 1M cause I added a 1M resistor. but there is probably a resistor in the circuit so I don't know, could measure it but I'm going to scrap the preamp that amp has, keep the active tone control and build a tube preamp for it.
in short: I was confused, didn't do any research, got it figured out, kinda.
thank's anyway!
Offline ArthurDent
« Reply #7 on: February 05, 2020, 02:34:23 pm »
"I dunno, I just threw it together cause I wanted more gain"
A cathode follower is an impedance converter to prevent loading the previous gain stage and it will have a gain less than one. This is basically how it is used as a pass element in a power supply where the output voltage on the cathode of the pass stage 'follows' the grid voltage and is almost the same value.
« Reply #8 on: February 05, 2020, 10:31:32 pm »
I know, it has lower than 1 gain so it only attenuates the signal. that's why I made a gain stage before it. I wanted the cathode follower cuz it was a solid-state amp I was feeding it into so  I didn't know what input impedance it was.
they are also used a LOT before tone stacks, cause tone stacks can load the input a lot more than just a gain stage. and cathode followers have a much lower impedance output
