Author Topic: [SOLVED] Weird behaviour in motherboard repair  (Read 1074 times)
Offline mlefeTopic starter
  • Country: ar
« on: April 22, 2018, 09:01:31 pm »
Hi guys, i'm trying to repair a laptop that has a fan that doesn't work.
When I measure resistance between an IC pin and the VFan_OUT pin on the fan connector I have a short (as expected) but when I connect the fan and measure again I can read more than 50K and raises until it OLs the meter (like if I was measuring a cap)... this is completely unexpected as I don't see how adding something can change the previous short... what am i missing? Thanks!
« Last Edit: April 24, 2018, 06:49:23 pm by mlefe »
Offline Shock
Re: Weird behaviour in motherboard repair
« Reply #1 on: April 23, 2018, 02:04:09 am »
So are you saying, you're measuring a low resistance trace on the PCB and getting an odd measurement when you connect the fan?
Do you have a link to the schematic and is there any power/battery connected to the circuit or charged caps etc?
Offline IanMacdonald
    • IWR Consultancy
« Reply #2 on: April 23, 2018, 06:43:05 am »
Sounds like a residual voltage upsetting the meter.
Offline amyk
« Reply #3 on: April 24, 2018, 03:11:25 am »
You have the leads touching something slightly different, and a cap is being charged up by the meter's test voltage.
  • Country: ar
« Reply #4 on: April 24, 2018, 06:47:45 pm »
I feel embarrassed, it was a very dodgy connection, nothing else  :-[ :-\
Thank you all!
The following users thanked this post: Shock
