Author Topic: lm386 amp on a breadboard - oscillation  (Read 3640 times)
Offline iconTopic starter
« on: February 02, 2014, 10:20:56 pm »
Hi
Is it even possible to make an amp on a breadboard that doesn't oscillate? I had an LM386 kicking around, so I thought it would be amusing to wire it up, listen to some music while I play. I made the 'minimum parts count' layout from the data sheet, which has a 250uF cap in series with the speaker, and a 50nF cap/10R resistor in series to ground (from the output).
It buzzed horribly to start with, but I twisted the speaker wires together and put a 100uF cap in parallel with a 10nF cap directly across the power supply pins. Now no buzz, but it oscillates at 690kHz. Sounds kind of OK, and doesn't draw a huge amount of current (20-30mA), but it would be nice if it didn't oscillate!
Any ideas how I can tame it?
Many thanks
John
Offline Rerouter
Re: lm386 amp on a breadboard - oscillation
« Reply #1 on: February 03, 2014, 03:23:16 am »
10nF cap between inverting feedback pin and output pin,
« Reply #2 on: February 03, 2014, 08:21:25 am »
Thanks, I'll give that a go.
John
Offline blackdog
  • Please stop pushing bullshit...
« Reply #3 on: February 03, 2014, 11:50:57 am »
Hi Icon, :-)
Do not forget to use a capacitor from pin7 to ground, say 10uF (Bypass).
And the zobel network on the output, 10-Ohm and 47nF on pin-5 (output)
It is all in the datasheet, firtst page.
Minimum components circuits is asking for troubles  :-DD
Kind regarts,
Blackdog
Necessity is not an established fact, but an interpretation.
« Reply #4 on: February 03, 2014, 08:56:54 pm »
The bypass capacitor on pin 7 seems to have mostly done it - still a very slight wobble at ~700KHz, but there's too many wires trailing around...
Thanks
John
