Author Topic: Solenoid valve 2/2 way N.C., with 3 pins ? (21JN1R0V23)  (Read 1634 times)
Offline onesixrightTopic starter
« on: November 05, 2018, 05:34:29 pm »
Hi All,
I'm looking at a solenoid valve, and to my surprise it has 3 pins :o
I thought it would be normal a 2 pin connector (energised the valve opens, and vice versa). But here I have a data sheet for a solenoid with 3 pins. For the life of me, I can not figure out (from the DS) what the function of the 3rd pin is  |O
Maybe a simple switch?
Anyway, if someone could explain, awesome!?
Thanks a bunch! And a link to the DS.
https://www.ode.co.nz/pdfs/21JN1R0V12.pdf
Offline alpher
Re: Solenoid valve 2/2 way N.C., with 3 pins ? (21JN1R0V23)
« Reply #1 on: November 05, 2018, 05:41:11 pm »
Ground.
The following users thanked this post: onesixright
« Reply #2 on: November 05, 2018, 05:48:18 pm »
Ground.
I was overthinking it :-) Thanks   :-+
