Electronics => Beginners => Topic started by: Jbliss on February 23, 2016, 01:05:08 pm
This might be the wrong place.
I have taken out a celling fan in my house due to renovations and i get reading of 24 -25 volt AC across the fan wires and if they are disconnected then none of the fans in that part of the house work. I have looked up 24v AC fans and can't find anything. is this 24v being created from a transformer in the celling or ???
anyone with any knowledge of fans care to help
It's probably voltage induced from the nearby wires. Some meters have a low impedance mode for these exact occasions, it makes the input impedance of the meter just low enough (about 2k, IIRC) to put a bit of load on the measured nodes, so the ghost voltages disappear.
I can't say I would advise you to attach a resistor between the wires and try remeasuring. You wouldn't want things to blow up in your face, should you make a mistake.
Thanks Dave
whats weird is they have to be connected for the fans to work?
