Hi guys, (First Time posting)
I'm trying to build a pic controlled Fish feeder.
So far everything works fine except i'm not sure what my best options would be for controlling the motor.
At the moment it only needs to run in one direction, on off (figured no need for PWM). The motor is a 1.5V-3V motor and i'v been using a power transistor but it seems to not always run.
I' Found a 75N08 Mosfet which i figured could work but would like some input and i'm not to sure if i'v set my circuit up correctly for it.
I'v attached a schematic diagram of the circuit.
Any help or suggestion would be greatly appreciated.
Regards
