Duggerd,
Your RFID reader draws 20 mA, the ones suggested here are capable of supplying 500 mA and 600 mA. As long as the voltage is right, these will work, your device will only draw the necessary current from those, 20 mA.
You can connect any 12V device to these as long as it uses less then 500 and 600 mA
