Author Topic: changing diode and capacitors  (Read 830 times)
Offline MepakosTopic starter
« on: August 01, 2019, 08:22:48 am »
I need help guys. If you reverse the two diodes and capacitors what would happen?
Offline ogden
  • Country: lv
Re: changing diode and capacitors
« Reply #1 on: August 01, 2019, 08:28:06 am »
Draw schematic, compare to original. What you see?
« Reply #2 on: August 01, 2019, 09:20:15 am »
I think no current flows through D2?
Offline ogden
  • Country: lv
« Reply #3 on: August 01, 2019, 09:34:59 am »
Why you think so? Hint: Tr1 is transformer, it means AC voltage source. Look at both circuits assuming that all capacitors are non-polar, think again what happens. [edit] Do you really think that reversing diodes can introduce such a fundamental change as removing current from one of diodes? Why?
« Last Edit: August 01, 2019, 09:37:18 am by ogden »
« Reply #4 on: August 01, 2019, 09:58:08 am »
Because of the direction. I read that current flows only from anode to kathode of a diode and cant flow from kathode to anode.  If thats not the case maybe nothing would change if i reverse them.
« Last Edit: August 01, 2019, 10:00:08 am by Mepakos »
Online Zero999
  • 0999
« Reply #5 on: August 01, 2019, 10:14:49 am »
The transformer outputs AC.
In the original schematic, assuming node B is 0V, D1 conducts when the AC cycle is positive and D2 conducts when it's negative. If their polarities were reversed, then this would be the opposite.
