Components have specifications and ratings, which are separate.
For a resistor, the normal specifications include nominal resistance, percentage tolerance of that value from part to part in production, and temperature co-efficient (change in resistance with temperature).
The normal ratings include maximum power (without destruction or change in value) and maximum voltage (also without destruction).
The choice of rating (like power) depends on what the circuit will actually or potentially impose on the component.
